RCU Forums - View Single Post - Wing Sanding
Thread: Wing Sanding
Old 02-01-2011 | 08:32 AM
MinnFlyer's Avatar
MinnFlyer
Default RE: Wing Sanding
I use the 12" GP sanding bars too, but I rarely get too critical with it. I have a rough paper and a fine paper, I couldn't tell you what the numbers are but to me, it's really not that important.
What IS important is getting all of the dust off before you cover! I usually pat it down to knock off the loose stuff and then wipe it good with a tack cloth or a towel sprayed with a spray adhesive. You want the covering to stick to the WOOD, not the DUST!
