RE: looking for a phoenix 8
Wagner,
The Phoenix 7 suggestion is a good one. The airframe is readily available and is very well engineered. You use a P-7 ARF as a proof-of-concept plane and see how it works out before installing it in a hard-to-find classic.
I am curious if you can hit 200, Also, I did a quick check of your power numbers. You might need a bigger ESC. To get 3000 watts on 6S, you'll be pulling over 120 amps. That assumes full charge and no voltage drpression from the load.
When you fly the E-Phoenix, please post the results.
Rob
