RE: watt meter
Well emederos, I used to do that too. I would follow what other people had been running. Yet I found it did not work as well for me as it did for others. So I figured I could throw $20.00 out the window and get a watt meter. I have found that it works very well. I used an online calc program to figure out what I should run and it listed the amps it should pull. Well it listed at at 57 amps and I am only pulling 49 amps. Plus I get a lot longer flights then it said I would get.
Buzz.
