RCU Forums - View Single Post - Herr Engineering Star Cruiser Build
Old 02-02-2011 | 09:13 AM
  #39
ejam
Default RE: Herr Engineering Star Cruiser Build
What I would do is mount the primary rx on the side of fuse around the battery area. Then run the sec. rx behind the tail servos. Things look tight. Is that a servo controlled speed controller? If so, you can replace that with newer Electronic speed controller.
