ORIGINAL: jmedley
I am following your thread and have the opposite question. I am just finishing up a PT-20 trainer kit. There is an option to include the ailerons or lock them. The ailerons are to installed, but the servo is left out and the ailerons are fixed in a neutral position. The servo can be installed and the lock removed at any time. I have zero hours of flying time and intend to start to learn. Would it be better to go ahead and install the servo when I start or go ahead and learn as a three channel plane?
Thanks for your advice
Jim
Yes!
If you plan to move ahead and flying more, youll eventually use ailerons.
BTW, my first solo was with a PT-20 and the worst kit I ever built. [X(]
