RCU Forums - View Single Post - Time For Your Input!
Old 02-03-2011 | 05:43 AM
  #32
Vettdriver's Avatar
Vettdriver
Default RE: Time For Your Input!
Todd,
Love your stuff.
I always wanted to see a fitting that uses bleed air from the turbine to
fill/keep full the retract system.
It would probably need a ball-check type valve coming from the turbine side
and a pressure release to prevent over pressuring on the retract side.
To avoid many of the temp issues, I am guessing we could drill & tap into the diffuser just past
the compressor.
I'll give you a week or two and start checking my mailbox.
