RCU Forums - View Single Post - Time For Your Input!
Old 02-03-2011 | 07:03 AM
  #33
lov2flyrc's Avatar
lov2flyrc
My Feedback: (24)
Default RE: Time For Your Input!
Ok... A few responses:
Cheaper hysol type epoxy - Will do some research but not sure we can find a better quality product for less money.
more ready available, scale cockpits - Great idea but not practical from a manufacturing standpoint (every airframe has different sizing )
Dreamworks to use Paypal - ALREADY DO!
bleed air from the turbine - Not Practical; turbine case pressure not enough to drive most gear anyway.
Universal landing gear Toe-in/out measuring tool - Will consider
3-piece electric scale set for airframe balance - Will consider
Injection molded strip piano hinges - Whats wrong with the Brass ones?
fuel monitoring tool - Possible but difficult to do right and still be cost effective. Will consider
switch/redundancy system specifically for the A123 cells - Will Consider
turbine/pipe alignment tool - Will consider
Universal" direct steering mechanism - Almost completed
quick connectors protective cap - Will consider
wooden mount for holding a UAT - Will consider
Better Gear door hinges - Already in development
combined airline/electrical connector - Will Consider
Larger cockpit and cover spring latches - Hard to get much better than [link=http://dreamworksrc.com/catalog/product_info.php?products_id=1001]THESE?[/link]
Electronic Door Drive System - Already in development!
Electric Retracts Heavy Duty - Already in development!
Built-in hopper tank inside the main fuel tank - Not Practical
A good gyro system with pitot tube - Not sure I even understand the purpose of this?
Pre-wired multiplex connectors - Why? Better to solder at a connector than inline?
Automatic safety wire applier, twister, cutter and crimper all in one step - Yes, you are dreaming :-)
quick connect and discounnect fuel filters - Adds yet another potential leak point!
Color coded servo wires - I assume you mean extension leads?
high quality connectors for several servos - Already have these! See [link=http://dreamworksrc.com/catalog/index.php?cPath=59_110_84]HERE[/link]
good tubular alum field work stand - Will consider
Great suggestions guys! Keep them coming!!!
