Originally posted by GOFLYIN
Did as you all suggested and then some ... no change. I even thought it might be a bad servo some where so we disconnected each channel one by one. Still nothing. We did discover that when the antenna wire is held streight verticle out of the center of the fuse everything cleared up. Additional thoughts? Could it be the ignition box is bad?
You must have a problem with your ignition system. What spark plug does the Fox use? Can you get a resistor plug for it? (It will have an R in the number) If you can't get a resistor spark plug the shielding for your spark plug lead must have a break and is leaking RF. I would send it back to Fox for replacement.
