RCU Forums - View Single Post - Balsa USA 40 size Taube
Old 02-03-2011 | 03:02 PM
multimike
Default Balsa USA 40 size Taube
I have mine all framed and ready to cover, I made the top deck removable right to the firewall to get access to the fuel tank and Rx battery, I modified the tail control surfaces and fins to stick construction , instead of sheet balsa, built everyting aft of the wing as light as possible, I have a 46 Enya FS up front which sticks out further than the recomended 40 I have the Rx battery right up against the firewall, the servos as far ahead as possible and before covering it is still going to take at LEAST 6 oz of weight in the nose to get it anywhere near the recommended C/G, where did I go wrong ?? Does nayone else have this problem ?? Mike
