RCU Forums - View Single Post - SuperTigre G90 in 60 Stik Problems
Old 02-03-2011 | 03:04 PM
Mr. Canadian's Avatar
Mr. Canadian
Default RE: SuperTigre G90 in 60 Stik Problems
I too have a ST G90 that i'm breaking in, and I also run 15% nitro. I used to have the exact same problem as you with the motor quitting in flight and running fine on the ground. I found the best solution for it was to richen the high end, then tune the low-end and keep a high idle. I also like to warm the engine up a bit before every flight.
