ORIGINAL: Ali
Hi Mike, I am with you on the Gas start!
Direct from JetCat
the P20SE- ECU is no problem, but the P20SE- fuel pump is only for max. 10V, not more!!
You can don’t use 3 cells A123, 2 cells A123 is to low.
You can use only 2s- Lipo battery.
Regards Al
A123 three cell pack is 9.9V nominal.
