RCU Forums - View Single Post - Return to pattern
Old 02-03-2011 | 05:37 PM
desertrider49's Avatar
desertrider49
Default RE: Return to pattern
I have 25 flights on my wind 50 and on the low horizontal line when the plane passes me the wingtip disappears. I'm considering putting some yellow covering under the wing to see if that helps. If I could do it all over again, I would probably buy the Osiris. I bought the Wind because of the removable tail, but that hasn't been an issue. Well, that's not true, I had to do some extra work to get the stab to stay tight against the fuse and not wobble around.
With the Wind you have to buy 6 cell batteries and the Osiris runs on 5 cell, so if you move up to a plane that runs on 10 cell you already have some batteries to use.
