RCU Forums - View Single Post - The reason JetCat's are boring
Old 02-04-2011 | 04:28 AM
BaldEagel's Avatar
BaldEagel
Default RE: The reason JetCat's are boring
On second thoughts the Pump voltage is possible controled in the same manner as an ESC controls an electric motor in which case it sees the ECU voltage the whole time and is switched on and off to control the speed of the pump, this is suposition on my part and I am only quoting the information I have received. i.e. the pump can not take over 10 volts.
Mike
