RCU Forums - View Single Post - SuperTigre G90 in 60 Stik Problems
Old 02-04-2011 | 09:31 AM
opjose's Avatar
opjose
Default RE: SuperTigre G90 in 60 Stik Problems
It's also a good idea to use a prop with a relatively high inertial mass until you've run several gallons through the engine.
APC props are good for this. They are much denser than a wooden prop or something like an Master Airscrew prop.
The additional mass helps keep the engine running when it is struggling during breakin and it helps maintain a lower idle speed.
Insanemoondoggie:
Been there... richen the low speed still more, even if it seems like you cannot get a low idle... then try flying the plane... but be prepared to land hot.
If this cures the in-air transition problem ( I bet it will! ) then you may want to use my "fix" for the low idle speed setting.
On similiar behaving SuperTigres I've taken to adjusting the LS richer then making a small half moon shaped cutout at the point of lowest throttle barrel closure. A small round file works fine for this, though you'll temporarily have to remove the throttle barrel to make the cutout.
This extends the LS range slightly while making it a bit leaner... I posted pictures of this on another thread.
The slightly enlarged opening permits you to close the throttle even more, while maintaining a leaner LS mix in spite of the richer LS needle setting.
It cured my transition problems on all similiarly aflicted ST 75 and 91 engines.... though not ALL ST's I have seem to have this problem.
