Seagul pc-9 .40 HELP ! !
I just built this bird for a friend and I used a Dubro tank and put foam above the tank and the battery pak under the tank and the CG came out just right by doing this. also make sure you epoxy the inside of the firewall because I found some holes that didnt get glued in right.
