RCU Forums - View Single Post - type of rubber cement?
Old 02-05-2011 | 05:19 PM
philipat
Default type of rubber cement?
I've seen several posts where folks mentioned using rubber cement to secure some items on their tanks that they want to be able to remove later. Specifically, I thinking of using it for metal sprockets to hold the hub caps in place. As they are, they fit tightly, but I'm concerned that they will fall off with outdoor driving. And, I don't want them to be permanently glued in place, because I might want to take them off the tank later.
So, here's the question: what rubber cement have you been using? Is it just the basic Elmer's craft cement that I can get at Wal-Mart? It seems like that is mostly used for paper; so, I thought I'd see what others are using first.
Thanks.
