RE: 82'' HAWKER TEMPEST Mk V 'Unknown Origin' build thread.
Hello chaps, I have built the rudder today which was similar to the elevator with 2mm balsa outline with ribs both sides built over the plan. Its now ready to be drilled for hinge points and covered using solartex. I have started working on the fuse with sanding the join line with the dremel ready for filler and I have cut out cockpit and opened up air intake under spinner. Word!
