RE: Lock Washer
They are not used because they are not needed. If you are throwing props, it is a sign that you are doing something wrong.
So from the description of on happening in the air, I would get it happens when you are starting. It is very easy to over prime an engine and when you put the starter to it, the engine kicks back and you loosen or remove the prop entirely. Is this what happen?
