RCU Forums - View Single Post - BVM LE flap.
Thread
BVM LE flap.
02-06-2011 | 09:43 PM
10
SCALECRAFT
My Feedback: (
13
Jan 2002
2,649
1 Post
MONTEBELLO, CA
RE: BVM LE flap.
Ok, the first pic is of the LE flap. It is a basic bent wire linkage that extents approximately 3" into the LE flap. It has a brass "flag" soldered to the rod for the ball link to connect to, then a 4-40 all thread rod (or bolt) that connects to a clevis to the servo arm. The flap has a 1mm step that the stops the flap from being pushed up past zero and also acts as a stop for the servo to keep a minor load on the flap. Secure no play is key.
I may also install a locking pin via golden rod wire at the root of the LE flap that slides into the flap and keeps it from movement. It may be on a separate servo or the same flap servo. ??
The other pic is of the aileron/flaperon. Same idea as the LE flap.
The trick to make this group of servos work together is the radio I have. The JR 9303. Basically, the radio has to be in Flaperon mode that control two separate aileron servos,that are on separate channels, not Y-connected, then you mix another channel in as the slave for the LE flaps.
This is what works for me and the radio I have. It took a week of reading the flaperon section, mixing section and mocking up servos and mixes and switches. The mixing is unlimited.
Hope this helps.
Steve
Reply
Like
SCALECRAFT
View Public Profile
Send a private message to SCALECRAFT
Find More Posts by SCALECRAFT
View iTrader Profile
