RCU Forums - View Single Post - 2 questions
Thread: 2 questions
Old 02-07-2011 | 08:36 AM
ATVAlliance's Avatar
ATVAlliance
Default RE: 2 questions
CGR...not sure the outcome if you use 2 different servos for each elevator.  I used 2 identical ones (actually were DS821's) and like I said...works perfectly.
I did not mix it with rudder though.  But Im sure it will work just fine.  Just be sure to check the throws in your mix if you want to mix the rudder with elevator.
