RE: BVM LE flap.
Having fixed 'stops' to limit past zero and past 'full deployment' on your LE or TE flaps can cause over travel / high amp current drains with your servos, particularly with digital servos. You may need some type of overtravel limiter on your servo arms: something like the spring devices that used to be used to prevent overtravel on the throttle servos for gas bangers.
