RE: Lock Washer
Hi HighPlains
You are absolutely right, over torquing is bad. It is bad when clamping metal plates, or our props. How do you prevent over torquing, but also use the correct torque to prevent problems? Interesting. Who should supply the torque #? Maybe the prop manufacturer. I'm not suggesting anything.
