RE: PST REVISION BUILD
As I feared... My Revision build was progressing well, but a job for a TV show that involves 2x P200 Sx's has come up, which means all tools are downed on the Revision for this week.
I will try and update on some of the work I have done so far.
Heads up.. I showed earlier where I had run a fillet of hysol on the nose woodwork to strengthen it... If you do the same just make sure that you stop that fillet about an inch from the outer edge of the woodwork. The reason being that the nose cone has 4 slots in its retaining former. So not only is the nose cone bolted through the front, it also neatly slots onto the internal cross woodwork. My hysol fillet was stopping these slots from sliding all the way back and seating the nose correctly.
