RCU Forums - View Single Post - M41 electronics problem
Old 02-08-2011 | 07:27 PM
Captain Action's Avatar
Captain Action
Default RE: M41 electronics problem
The wires you are talking about are vary thin and cheep also usually vary poorly soldered together.
They are also connected together so it makes sense that you would have both stop functioning.
Check the wires,then the solder, look at the small hook up board attached to the top hull, if they are good it may be the board .
Good luck
