RE: Gyros, whose are you using?
gy-401 is a good servo, as I use them in my heli's.... setting all depend on the servo you use. make sure you have the gyro set for the right servo, ie; digital or analog. when it is installed, test run the jet on the ground and adjust to you liking. my setting my be different in your aircraft.
Mark
