RE: electric to nitro.
Assuming you have also installed the fuel system, then yes, the throttle servo will normally plug into channel 3 on the reciever(where you would normally plug in your ESC). Your battery pack will plug into the female lead on your switch, and the male lead from the opposite side of the switch will plug into the battery port on your reciever. Your switch may have a male and female lead on one side and a male lead on the other, if it does, the male lead that is on the same side as the female lead is a charge plug for charging the battery. Welcome to nitro! there are pro's and cons,that's why I fly both. Hope you will enjoy it and hope I answered yourquestion!
