RCU Forums - View Single Post - When does a four stroke need a new ring.
Old 02-09-2011 | 07:17 AM
blw's Avatar
blw
Default RE: When does a four stroke need a new ring.
I would first make sure the low speed needle is set as lean as possible and still give good throttle response. I would check compression like Earl said. Be sure to open the throttle some when you check it.
