RE: Wheel Help
I'm guessing about +8mm on top of what they are should sort you out, best if you measure it with a good ruler though, and bear in mind if they stick out at all they will rub on the shell.. If you have a look in your bits you might have some wider wheel locator things, the ones that go behind the wheels and are held by the pins. I got some with mine, but only a pair of them.
