RE: CA Model XURAMA BIPLANE Build Glow Powered
Hey Guys! about the lips on the cowl, Jim you are right. Iwill use some carbon to strength arond the cuts, then im still decinding if I will make a folded lip (like on the top hatch) or a simple lip. first I need to get some structure inside the fuse then I will work on that. this is because I dont want the fuse to twist while making the lip, first I have to make it stiff again.
about the top hatch, I just dont know yet, so far it seems like I will have to close it to add strength, but after the internal structure is done I will see. it woud be very nice to keep the acces hatch.
thanks guys!!!
TUNY
