RE: bl drift setup help
thanks for the replies. in the listing it says :<div><span style="font-family: arial; -webkit-border-horizontal-spacing: 2px; -webkit-border-vertical-spacing: 2px; font-size: small; "><p style="margin-top: 0cm; margin-right: 0cm; margin-bottom: 0pt; margin-left: 0cm; " class="MsoNormal"><span style="font-size: 11pt; " lang="EN-US"><font size="2">3 running modes (Forward mode, Forward/Reverse mode, Rock Crawler mode).
4 steps of maximum reverse force adjustment.
Proportional ABS brake function with 4 steps of maximum brake force adjustment, 8 steps of drag-brake force adjustment and 4 steps of initial brake force adjustment.
<font color="#FF0000">9 start modes (Also called "Punch") from "very soft (Level 1)" to "very aggressive (Level 9)".</font>
8 steps of timing adjustment to suitable for all brushless motors.
Multiple protection features: Low voltage cut-off protection / Over-heat protection / Throttle signal loss protection / Motor blocked protection.
Firmware updatable, but always with zero timing.</font></span></p><div><span style="font-size: 11pt; " lang="EN-US"><font size="2"><font color="#000000"> so i guess it would be fine if i put it on to level 3 or something. </font></font></span></div><div><span style="font-size: 11pt; " lang="EN-US"><font size="2"><font color="#000000">as for the motor i guess it is a bit on the powerful side but i am going to be changing the setup to 'track bashing' sometimes so i wouldnt mind having some more power probably. anyway it doesnt cost that much so i can just downgrade a bit and use this motor in something else.</font></font></span></div><div><span style="font-size: 11pt; " lang="EN-US"><font size="2"><font color="#000000">
</font></font></span></div><div>regards posting i put that in because most guys reply with links from US pages and most dont send to malta so that is why i added it in. but yeah, thats what i end up doing mostly. ask if they ship here and so on.</div><div>
</div><div>thanks for the replies.</div><div>dave</div></span></div>
