Original:Av8tor1977
I've been contemplating lately how much help the use of a primer bulb on our planes could be, and how many problems it could solve, especially for newbies. I know, I don't really want one on my plane(s) either, but it does have some logic. When someone says "firing up your (weedeater, leaf blower, chainsaw)??" when you are using one on your plane, just tell them "Hey, at least my plane always runs!"
Here's the "argument". Most people don't have a clue about how a primer bulb system works, but it is pretty ingenious actually. It does
not "push" fuel to the carb, and it does
not "inject" fuel into the engine. What it
does is
<u>draw</u> fuel from the tank all the way into the regulator fuel chamber. It creates a suction that moves the regulator diaphragm open, which opens the inlet needle valve, which allows fuel to be drawn from the tank, through any filter you might have in the tank, through the inlet fuel tubing, through the fuel pump, through the inlet screen in the carb, past the regulator needle valve, and finally into the fuel chamber. The excess is then expelled through the other line in the primer bulb system, and dumped back into the tank.
So think of what all this accomplishes:
1. Flushes old fuel out of the carb and replaces it with fresh drawn from the tank.
2. Proves that the filter in your fuel tank is flowing.
3. Proves that there is probably no kink nor obstruction in your fuel feed line to the engine.
4. Proves that fuel can flow through the fuel pump, indicating that the check valves in the fuel pump are wet and probably functioning. (At least the inlet flapper valve is not stuck.)
5. Proves that the inlet screen in the carb itself can flow fuel.
6. Proves that the inlet needle is not stuck shut. (I have had this happen.)
7. Proves that the regulator diaphragm is not stuck in the closed position. (It still could be too stiff to operate correctly but at least it is opening the needle valve.)
8. Proves that there probably not an air leak at the fuel pump nor diaphragm
cover gaskets.
9. Prevents the "dry carb won't draw fuel" syndrome.
Interesting heh?? I fix a lot of yard equipment, and the first thing I do after checking compression and spark is to put fresh fuel in and pump that primer bulb. If it doesn't pump fuel and fill up, the very
first trouble shooting step is to find out why not.
AV8TOR <span class="info"> </span>
