ORIGINAL: Silent-AV8R
ORIGINAL: KidEpoxy
but we are going to use the ARC provided exemption to get AMA out of the ARC listed troubles.
This is the core of your problem. You view the ARC recommendations as
providing something or being the basis of the Rule, which it just flat is not.
Well, unless things are perceived as positive then I guess you would likely say otherwise... But let's just go with what you have just said... it would then follow AMA's involvement was providing nothing positive as well... Now, if you can say that... then your statement above rings true. Otherwise we are just listening to the other side of your mouth.
