RCU Forums - View Single Post - symmetrical wing question..
Old 02-11-2011 | 09:25 AM
ARUP
Default RE: symmetrical wing question..
ORIGINAL: BMatthews
Arup, on a control line model you'll automatically and unconciously select the amount of up elevator needed to fly level in any event So your model will not truly be flying at an actual 0-0-0. It'll be 0-0-x due to the slight up trim needed to hold level flight. Only during the vertical parts of squares and wingovers will it truly be 0-0-0 when the model is pointed straight up or down.
Thanks for clarifying the point I was trying to make. Changing the elevator causes a change of stab-elevator combo incidence as a system which then changes AOA of wing.
