RE: CA Model XURAMA BIPLANE Build Glow Powered
more...
Finished the landing gear mount, then made the fron former for the landing gear structure, is made from 1/8 lite plywood ad carbon on both sides, same way as all the others.
then sanded all the surface of the formers with 100 sandpaper, this is to have a very good grip for the epoxy, also sanded the inside of the fuselage where the pieces go. this is very important to make sure I have perfect glue joints, also is a good idea to use the same epoxy for all the work , laminating and joints in the fuse.
then glued the rear former and the landing gear mount in place. with this in place the fuselage is already very strong again.
pics...
