RE: Banned Again 1st and now last.
I don't get it. It's obvious the AMA forum doesn't tolerate criticizing the AMA. So why go there and do it? I haven't ever even visited the AMA forum, partly because RCU gives me all the information I need and partly because of the negative comments I've seen here about it. If the forum is no good, then just don't go to it. Yet some go and start trouble not just once, but multiple times. They get disciplined based on the rules of the forum, then come here and complain! Hossfly, you got what you wanted. If a guy doesn't like the AMA forum or the way it operates, the best thing is to just leave it alone. A small group of goobers will likely populate it for a while, then the AMA will eventually either change it or take it down.
