RE: Shelf Life of Cool Power?
I think that would be an interesting test, but the results would depend on where you did the test (humidity of some areas are 100% while others are 5%), plus the level of ventilation of the room (partial pressures of methanol vapor may affect the results).
With a good triple beam balance, couple chunks of ice, and water, you can tell the temperature of your freezer without a thermometer.
