direct or mini gearbox
hi need some info
would using a direct drive i.e stern tube with shaft direct to motor via universal joint be less noisy than running it using a 2:1 mini gearbox?mini gearbox hasplastic gears and is noisy or is it that the gears are worn.
cheers
