ORIGINAL: MTK
Anyway, I prefer stab and wing closer to thrust line so that's where I am going in my set-up. I raised the stab CL 20 mm. Wing CL is set at 15 mm below the stab CL (meaning the wing was raised), or an average of about 95 mm below the center of the canopy's deck. Downthrust is zero
So you are going to re-position the wings on your rebuild, interesting!
How much dihedral are you going to put into the wings measured at tip from root cord or center line??
Regards
