RCU Forums - View Single Post - DERIVATIVE, New 2X2
Old 02-15-2011 | 07:50 AM
MTK
Default RE: DERIVATIVE, New 2X2
ORIGINAL: DagTheElder
ORIGINAL: MTK
Anyway, I prefer stab and wing closer to thrust line so that's where I am going in my set-up. I raised the stab CL 20 mm. Wing CL is set at 15 mm below the stab CL (meaning the wing was raised), or an average of about 95 mm below the center of the canopy's deck. Downthrust is zero
So you are going to re-position the wings on your rebuild, interesting!
How much dihedral are you going to put into the wings measured at tip from root cord or center line??
Regards
Dag,
Both wing and stab are moved. I like them both closer to the true thrust line of the model.
A separation of wing (lower) to stab of 14-15 mm requires 1.5 degrees of dihedral per panel (3 degrees inclusive) for zero roll couple. For my wing design this works out conveniently: I build in the sockets with the wing upside down, flat on my refernce table.
I've used these parameters for years with really outstanding success. I expect similar with this fuse. The main variable is fuse depth.....much much deeper than anything I've built earlier. We'll see if I need to build a second wing with different dihedral
