RCU Forums - View Single Post - Seagull PC-9 120 size...
Old 02-15-2011 | 01:00 PM
  #63
Anderl7890
Default RE: Seagull PC-9 120 size...
Hi guys
Mi very simple solution to any stall problem: Keep weight as low as possible!
Therefore is deceided to install a geared motor solution with just an 6S battery driving a 17X14" prop.
The complete propulsion system including motor, gear, battery, ESC and prop weights only 2.65lb
Not trusting in the mechanical solution iinstalled a robart 510 series retract.
The only problem i have: The canopy does notnot fit. I have a gap of half an inch on each side ofthe canopy.
I already reworked the fuselage side atthe canopy section but therestill is a gab of about 1/4"on each side
between canopy and fuse.
I don't know how to get a good fit, which really lowers my anticipation about that model.
regards
Andi
