RE: Mounting Servos inside Wing
Hi JoelStolarski
I notice you are using a steel screw-on clevis on each end of the control rod. It would be best if you use Loctite on one of the clevises so that the rod cannot turn and possibly get lose. Some people will add a nut to jam the clevis. I always use a Z-bend on one end. I'm to cheap to use two clevises. When is the maiden?
