RE: 1/4 scale F9F Panther build
On Saturday another ground hog day for Dennis and Mr fun. More sheeting and another intake layup. they did start to build up the vertical on Johns plane and also spread some bondo an Hals foam canopy plug to harden it and start to get it to final rough shape Hal will get it to final shape with some templates he made. I cut open F-1 after glassing the nose. this exposed the box to locate some heavier components. I also keyed the nose in that will cover the opening and give me access. I worked on my wing plug ins that will be glued into the foam cores and then ground down to the airfoil shape. I also made a few plywood tools to cut the spar slots for the stab and wiwgs
