The motor on my son's Fledgling(gen II, brushless) has gone out again. It uses a cheapo from HobbyKing. It's a 3015-7 and below are the listed specs from HobbyKing website.
http://www.hobbycity.com/hobbycity/s..._1000kv_/_470W
Model: TowerPro 3015-7
Weight: 133g
Voltage: 10v
Idle Current: 2.2A
Suggested Battery Config: 3-4Lipo
Kv: 1000RPM/v
Shaft: 5mm
Max Eff Current: 30A
Max current: 40A
Max Power: 470W
Suggested prop: 10*5, 11*5
I bought this KMS 2814/06 motor from Hobbypeople and then found out the shaft size is different so i can't use the prop adapter.
KMS Quantum 2814/06 outrunner Ref: M-KMSQ2814/06
Max. Continuous Current (Amps): 24
NiCad/Ni-MH: 7-10 cells
LiPo: 2-4 cells
I0: 2A
Turns: 6T
KV RPM: 1290
Diameter: 35mm
Max Current: 32A/60s
Propeller Range: 9.5 x 5, 9 x 6, 10 x 4.7, 10 x 5, 10 x 6
Resistance: 45 mohm
Bearings:
pole: 14
ESC Timing Degrees: 20-30 (high)
Weight: 103g
Length: 36mm
Max Efficiency: 80%
Shaft dia: 4.00mm
Is this motor a good replacement? Is there a prop adapter to use on the long shaft?
skeeter
