I think it looks good part from one thing...
What sort of gear ratio are you looking at there?
Judging by the drawings your ratio is way off.
Depending on what sort of chain drive you're using you might have to consider using a second set of chain and sprockets to reduce the drive.
Pocketbike chain and sprockets are good as they're small and can be used straight off the bike, but mounting such a small sprocket on a chainsaw clutch can be difficult, if not impossible.
Depending on how the clutch is set up you might be able to do something like this:
That sprocket came from the cam in a dirt bike motor actually.
I'm looking forward to seeing more of this project though.
