RCU Forums - View Single Post - Running CDI from RX
Old 02-16-2011 | 01:30 PM
Teachu2
My Feedback: (133)
Default RE: Running CDI from RX
ORIGINAL: MTK
ORIGINAL: Tired Old Man
It's your plane and your money, but as Pe noted, it's not just your risk. Bear that in mind if and when something happens. Your only arguement is that these devices shave a couple ounces of weight. That's a very poor reason to place everything and everyone at risk.
Nope...Wrong on that one. Safety is actually enhanced, on the ground especially. I've seen guys put their hands through props trying to get to a switch.
The overall risk is probably no worse or better though. An extra bat and switch have the same number of connections as the IBEC adds. Can the IBEC die? Sure...so can the battery or switch. The result is no different, one compared to the other...engine dies. One small difference, the Tech Aero IBEC actually tells you when it's dead or not armed
I use the 42% optically-coupled kill switch. I can kill the motor from the Tx, and if the rx loses signal or battery the switch instantly kills the ignition. This makes it pretty hard to come up with a scenario that would result in a powered fly-away, and still preserves the isolation of seperate rx/ignition power sources.
