RE: HELP WITH MOTOR!!
It looks like you need to take off that C-clip that hold the shaft in place and drive the shaft so it protrudes from the front of the motor. At that point you will be able to either re-use that same C-clip if you did not damage it or just add a new one to hold the shaft back in place. Then you will be able to either use the adapter that is shown in the picture or use the prop-saver.
