ORIGINAL: pitstop000
Ralph, thanks for sharing the Build with us.
Let your Dad know we appreciate his contribution on the project as well.
Thanks for label and templates, they arrived intact.
The Label Quality is excellent.
Thanks Paul! Will do! Hope the label works out for you.
RG
ORIGINAL: Roguedog
Hey Ralph,
Do you already have your bow setup? I was also curious as to the type of hot wire you use. Maybe you could post some pics of what you use to cut the foam with. Would be neat to see your Power supply hooked up to your cutter.
Bryan
Bryan,
I made a bow a while back to cut the wing cores for my UFO build. The construction of the bow with more pics is shown [link=http://www.rcuniverse.com/forum/fb.asp?m=10042580]here[/link]. I ended up using .015" control line flying wire for the hot wire. It worked pretty well.
Ralph
ORIGINAL: edwarda10pilot
Ralph:
Can you provide some info on the material you used on the label and how it was made/printed?
Ed
Ed,
The label is made from vinyl and was printed and cut on my vinyl printer/cutter. I have a part time, home based graphics [link=http://www.rggraphix.com/]business[/link]. Keeps me busy while I wait for the glue to dry on my model projects!
Ralph
