RCU Forums - View Single Post - Running CDI from RX
Old 02-18-2011 | 06:46 AM
  #45
pe reivers
Default RE: Running CDI from RX
That's right Manuel. This certification allows the ignition to be used in a sensible way.
Shielding damage should also be taken into consideration for airborne RFI. But this discussion is about galvanic coupling through the cable harness when the ignition is plugged into areceiver channel.
can I power an electronic ignition for a DLE 30 from the receiver?
