ORIGINAL: glenny22072
I'm having problems with dx6i and ar6200, everythings hooked up proper but not getting and aileron control,,anybody got any ideas?
I will ask a few of questions. Do not be offended.
Is this the first time you have set up this Tx with this Rx?
What type and size of Rx batteries are you using?
Are you sure that the Transmitter and Receiver batteries are fully charged?
Did you follow the procedure to Bind the Tx to the Rx?
Insert Bind Plug into the Bind Port on the Rx.
Turn on the power to the Rx.
Watch for the Blinking Lights on the Rx.
Depress the Bind Button on the Tx and turn on the power to the Tx.
The Blinking lights on the Rx will go out and come back on Solid.
Remove the Bind Plug.
Turn off Rx and then Tx.
Turn on Tx and then Rx.
Lights on Rx should come on Solid and servos should move with sticks.
