RCU Forums - View Single Post - BDC Moved
Thread: BDC Moved
Old 02-18-2011 | 03:54 PM
378's Avatar
378
Default RE: BDC Moved
Heh, I had an engine snap a crank because of a loose flywheel. Smoke it on as tight as you can, you won't break the crank unless it's already cracked. Just do NOT use something stuck in the glow plug hole to lock the engine while doing so, grab the flywheel itself instead.
